Graph View - Highlight Current Node more Noticeable
Problem
It is difficult for me to find the current note in the graph.
I would therefore suggest a marker for the current note - a purple ring.
Current Note
If there should subsequently be a button to center the view around the current note, you could animate the ring briefly immediately after centering to draw attention to it. The animation could be a brief increase and then decrease of the ring. The power-ups from Super Metroid (SNES) come to mind. :slight_smile:
Related feature requests
You were also asked to search first. :slight_smile:
I’ll merge this with the existing thread.
