Graph view filter entry
I use somewhat long filters when doing searches, and do so in Graph view too. When doing searches, I can expand the left sidebar so I can see and edit my whole filter. In Graph view, I can’t expand the configuration bar so I can only see a small part of my filter which makes entry/editing a pita. Am I missing something? Thanks.
I see what you mean. The filter bar doesn’t expand like it does for the core search or for the backlinks filter.
As a workaround, you can test your long query term in the backlinks filter, cut the query and paste it in the graph filter bar.
If it’s a local graph, you can save these queries with the Graph Presets plugin.
