Oh, I see.
Now that you are at it, isn’t “Vault-wide” more English than “Vault-wise”?
How about chicken paprikash?
Didn’t get it
Thanks to Obsidian folks for considering this feature request!
Just to add a use case: I have been linking to a note (that hasn’t yet been created) wiki-style from many other notes. I finally went to create the note today only to discover that since the name I’ve been using has a colon, I can’t make the note. Now I want to go back and replace all these links that link to a name with a colon, but there are several dozen. Find-replace would be perfect for this.
As a workaround, the in-page search-replace stays active when you switch between notes, so if you use it on one of the notes and then do a vault search for the rest of them, you can get thru them at nearly the same speed as a global replace that requires confirmation. Click search result, click Replace All, repeat. It’s not as fast as a global replace that doesn’t use confirmation, but useful to know.
Me too, VS Code global search is fire!
There is no good way to do this. I am also using VS Code
Is this search & replace on vault feature on the roadmap?
It’s not currently on the Roadmap. You can see that here:
Well that’s too bad. Seems basic enough that it should be…
This would make vaults more dynamic, and new workflows so much easier. +1
+1 to this
+1 to this too
+1 to this
+1 too
+1 to this request
+1 to this request
+1 to this request. (In the meantime, I use Bbedit.)
