Global Graph does not create connection in real time when a nonexisting note is created
Assume you have file a that links to [[b]] and b does not yet exist.
b shows in the local graph and does not in global graph. This is debatable.
Aside from this design decision.
If you do create b by clicking on the link. The global graph shows that b has been created but it does not show that it is linked to a, until you close and restart the global graph.
Both graphs should show connections to non-existing notes, right?
This part is a design choice, not a bug. Right now, in the global graph we are only showing exsisting notes.
This bug is about the online update of the local graph vs the global graph.
Will there be an ability to toggle this option in the future? I really preferred being able to visualize that deep, even if a note hasn’t been created yet.
Open a feature request for that.
will be fixed in 0.8.12
Postponed to 0.8.13
