Git sync with multiple repos in one vault - East way to push pull?
I have many distinct git repos in one vault.
I know the GitSync plugin is great if you sync your entire vault to git but I am not sure it’s much help if you, like me, have a bunch of different git repos.
With my current workflow I end up right clicking on the folder I am on that I know is a git repo and then going to the actual location of that folder on MacOS and then dragging it into Github desktop and doing a push/pull … or if the path is the same then presumably that repo is already loading in Git desktop and then I can just run updates or pushes from there.
But just wondering if there is a method to do this in the Obsidian GUI via plugin or other method to not have to move over to Github Desktop of another git GUI?
Thanks!
this is a niche case
there’s no such thing
there’s one git plugin
you can install terminal plugin and use it within obsidian…so to speak
then fire shell scripts that do what’s necessary for pulling all and pushing all
but that’s about as “gui” as it gets
