Hello everyone!
There are notes, there is a list of tasks on the notes, each task has a link to the note. Can I make it so that I can display a list of tasks that have a specific relationship?
This lists out only tasks that have links to the test file:
```dataview
TASK
FROM ""
WHERE outlinks AND contains(text, "[[_testingFile]]")
Source list …
… output with DataView query …
Hope it helps for further playing.
Cheers, Marko
EDIT:
contains()
is case sensitive! For details or other options, take a look here: Functions - Dataview- You can use it without square brackets, it’s just easier to filter/find files
