Has anyone tried generating code blocks with datacore?
This just outputs raw text:
return function View() {
return <p>```<br />fff<br />```<br /></p>;
I’m currently able to do this OK with dataviewjs in order to generate qr codes using the qrcode plugin. Just curious if a similar result is possible with datacore.
As an alternative, I am also attempting to load a QRcode library into dataview using require. It sounds like this was possible in 2021:
However, testing this I receive an error:
ReferenceError: require is not defined
2021 was some time ago. Is it currently possible to import js files into dataviewjs? I may also look to see if something similar is possible with datacore.
