I tried using the tasks plugin but it seems to be incompatible with the theme I’m using ( PRIMARY by ceciliamay ) as it supports custom check boxes.
I also tried using
TASK from date(today)
GROUP BY file.link
but it led to a parse error.
I effectively want dataview to include all tasks from that day’s daily note into the todo page. Tasks does not work, so I am hoping dataview has a solution.
What do your daily note filenames look like? And are they in a folder? To use FROM on a file, I think you need to give it the full path from the root of your vault.
They are in the form of YYYY-MM-DD.
I know I have to give the full path. I can’t keep changing the path everyday, however. I was hoping that someone would have a solution to this that would not require me to change the path daily.
And, yes, they are in a folder.
