Ganttchart with dataview and mermaid, stop showing tasks after 4 months
I have a 7 month project with about 30 tasks, going from Januari until the end of June.
The chart is created following this post:
Code used: Obsidian_stuff/dataviewjs/ganttchart-from-tasks.md at main · anantshri/Obsidian_stuff · GitHub
Styling thanks to [mnvwvnm] this post How to style GANTT chart (mermaid)? - #2 by ZKE
With the help of chatGTP and all above I was able to color the tasks (done/active/critical) and also see the done tasks also.
But for some reason the chart stops showing tasks after 4 months.
Everything after the first of May does not show up.
Changing the start dates to a date before First of May show the tasks …
Is this a ‘normal’ behavior, and as time (months) goes by the ‘missing’ tasks will show up in the Gantt chart ?
The code used, could be of use to someone.
// Priority mapping based on emojis
const priorityMap = {
    "🔺": "Highest",
    "⏫": "High",
    "⏺️": "Medium",
    "🔽": "Low",
    "⏬": "Lowest"
// Function to determine priority based on emoji in task text
const getPriority = (text) => {
    for (let emoji in priorityMap) {
        if (text.includes(emoji)) {
            return priorityMap[emoji];
    return "Medium"; // Default to Medium if no emoji is found
const today = new Date(); // Get the current date
const todayStr = today.toISOString().split("T")[0]; // YYYY-MM-DD format
const tomorrow = new Date(today); // Clone the today date
tomorrow.setDate(today.getDate() + 1); // Add 1 day
const future_date_max = new Date(today); future_date_max.setDate(today.getDate() + 90);
const tomorrowStr = tomorrow.toISOString().split("T")[0]; // Format as YYYY-MM-DD
const tasks = dv.pages("").file.tasks.where(t => t.text.includes("#fotoexpo") && t.start && t.due && t.status != "-") .sort(t=>t.start);
let endme="";
if (tasks.length > 0) {
    let ganttData = `
\`\`\`mermaid
gantt
    title Alle taken
    dateFormat YYYY-MM-DD
    axisFormat %d-%b
	tickInterval 1week
    // Group tasks by priority and create a critical group
    const priorityGroups = {"Critical": [], "Highest": [], "High": [], "Medium": [], "Low": [], "Lowest": [] };
    tasks.forEach(task => {
    const dueDate = new Date(task.due.toString().split("T")[0]); // Vervaldatum als Date-object
    const startD = new Date(task.start.toString().split("T")[0]); // Startdatum als Date-object
    const startDate = task.start.toString().split("T")[0]; // Startdatum in YYYY-MM-DD-formaat
    const endDate = task.due.toString().split("T")[0]; // Einddatum in YYYY-MM-DD-formaat
    const endD = new Date(task.due.toString().split("T")[0]); // Einddatum als Date-object
    const isCritical = !task.completed && dueDate < today; // Alleen onvoltooide en over tijd taken zijn "Critical"
    if (startD <= future_date_max) {
        const priority = isCritical ? "Critical" : getPriority(task.text); // Bepaal prioriteit
        if (endD > future_date_max) {
            endme = future_date_max.toString().split("T")[0];
        } else {
            endme = endDate;
        let sanitizedTaskText = task.text
            .replace(/#[\w-]+/g, "") // Verwijder hashtags
            .replace(/(?:\p{Emoji_Presentation}|[\u2600-\u27BF])\s*\d{4}-\d{2}-\d{2}/gu, "") // Verwijder data met emoji's
            .replace(/[\n\r]+/g, " ") // Verwijder nieuwe regels
            .trim(); // Verwijder spaties aan het begin/einde
            sanitizedTaskText = sanitizedTaskText.replace(emoji, "").trim();
        if (sanitizedTaskText) {
            if (task.completed) {
                // Markeer voltooide taken
                priorityGroups[priority].push(`    ${sanitizedTaskText} :done, ${startDate}, ${endDate}`);
            } else if (isCritical) {
                // Markeer kritieke taken
                priorityGroups[priority].push(`    ${sanitizedTaskText} :crit, ${startDate}, ${tomorrowStr}`);
            } else {
                // Voeg actieve taken toe
                priorityGroups[priority].push(`    ${sanitizedTaskText} :active, ${startDate}, ${endDate}`);
    // Add tasks to Gantt chart by priority
    for (const priority in priorityGroups) {
        if (priorityGroups[priority].length > 0) {
            ganttData += `\nsection ${priority}\n`;
            ganttData += priorityGroups[priority].join("\n");
    ganttData += `\n\`\`\``;
    // Debug mode: Show raw text
    dv.el("pre", ganttData);
} else {
    dv.paragraph("No tasks found with Gantt chart marker and with start and due dates.");
To answer my own question, I have turned off internet. changed the date to the first of April.
Yes the chart moves and showed all the data.
