I want to share with you the plugin I was working on for the last few months.
I created this plugin because I was tired of using the Obsidian-to-Anki or just simple Anki. I love Anki, but I really missed the ability to connect my notes. Anki also feels a bit too bloated for many use cases, and while FSRS is great, I wanted something more integrated with my notes, not just adding a source in anki template.
I’m a big fan of the SuperMemo flashcard learning approach, and I built this to have a complete, native solution inside Obsidian and to be honest with you, woooow!
Here’s what you get:
AI flashcard generation - one click from your note, or highlight a paragraph and generate from just that
Source tracking - click any question and it highlights the exact text in your note
Live editing during reviews - edit cards mid-session with full Obsidian wikilinks and hover previews
Image Occlusion - many of you asked for this in DMs, it’s here
SQL storage - even with 100k+ flashcards, everything stays fast
FSRS scheduling - the same algorithm that powers modern Anki, fully configurable per card
