Checked the troubleshooting and searched the Graveyard and current open Bug Reports, didn’t fins a similar issue.
- Installed Obsidian app on iPhone, created a Vault and named it ‘Brain’
- Created a new remote vault with paid Obsidian Sync
- Started writing some notes from my phone
- Installed a fresh Obsidian release on my MacOS (Version 1.3.5, Installer 1.3.5)
- Followed instructions from Set up Obsidian Sync - Obsidian Help to set up the Synced Vault on my laptop
- After the last step, after clicking ‘Start Syncing’, I’m getting a connected vault shown in the Settings, but in the sidebar the vault appeared as a nested directory, in the directory, in the directory, etc.
- When I check the directory structure on the disc it shows 161 nested Brain dirs with the last one being empty
Here’s my Sync log:
2023-07-09 21:55 - Paused
2023-07-09 21:55 - Connecting to server
2023-07-09 21:55 - Server pushed (folder) [MacBook-Pro.local] Brain
2023-07-09 21:55 - Server pushed (folder) [MacBook-Pro.local] Brain/Brain
2023-07-09 21:55 - Server pushed (folder) [MacBook-Pro.local] Brain/Brain/Brain
2023-07-09 21:55 - Server pushed (folder) [MacBook-Pro.local] Brain/Brain/Brain/Brain
2023-07-09 21:55 - Server pushed (folder) [MacBook-Pro.local] Brain/Brain/Brain/Brain/Brain
2023-07-09 21:55 - Server pushed (folder) [MacBook-Pro.local] Brain/Brain/Brain/Brain/Brain/Brain
2023-07-09 21:55 - Server pushed (folder) [MacBook-Pro.local] Brain/Brain/Brain/Brain/Brain/Brain/Brain
2023-07-09 21:55 - Server pushed (folder) [MacBook-Pro.local] Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain
----------------------------------- [ CUT ] -----------------------------------
2023-07-09 21:56 - Accepted Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain
2023-07-09 21:56 - Creating local folder Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain
2023-07-09 21:56 - Accepted Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain/Brain
2023-07-09 21:56 - Fully synced
Yes, I’ve tried everything, multiple times, including clean installation (with prior removal of /Library/Application Support/obsidian, etc.) It’s reproduced every single time.
I expect my remote Vault to be synced from the Obsidian Sync cloud and to show the same contents and structure I have on my iPhone.
The data is not synced and the structure is nested many times without any files in the deepest directory.
Obsidian version: v1.3.5
Installer version: v1.3.5
Operating system: Darwin Kernel Version 22.3.0: Mon Jan 30 20:38:37 PST 2023; root:xnu-8792.81.3~2/RELEASE_ARM64_T6000 22.3.0
Catalyst license: none
Legacy editor: off
