Hi,
I’d like to request the following new feature to the API.
I’d like to detect if the Ctrl
/Cmd
key was pressed when an extra button was clicked in settings. This can be done, if there’s access to a MouseEvent
object, because MouseEvent.ctrlKey
tells it (at least for Ctrl
, I’m not sure about Mac’s Cmd
key, because I don’t have a Mac).
If I’d use a ButtonComponent
instead of an ExtraButtonComponent
, I could access the MouseEvent
object. However, ButtonComponent
is bigger and therefore does not suit my settings layout, where I want to have small icon buttons. ExtraButtonComponent
is perfect for the layout.
Here’s a simplified example code describing the difference between ExtraButtonComponent
and ButtonComponent
new Setting(container_element)
.addExtraButton(extra_button => extra_button
.onClick((/* Callback has no parameters*/) => {
.addButton(normal_button => normal_button
.onClick((mouse_event: MouseEvent) => {
A workaround
.extraSettingsEl.addEventListener("click", (mouse_event: MouseEvent) => {
if (mouse_event.ctrlKey) {
This works, but is not as intuitive, and perhaps it can break if Obsidian API changes later?
Thank you for considering this!
