Footnotes in slides: On the same page, smaller, and clickable?
Rarely (so this is not high priority), I use footnotes in slides:
# Slide 1
Some text and a footnote.[^1]
[^1]: This is the footnote text.
# Slide 2
Even more text.
These are shown in normal text size at the end of the document, separated by a large vertical space, and not clickable.
It would be nice if they
  • could be shown on the same slide they appear on,
  • be in smaller size,
  • maybe have less vertical “separation space”,
  • and be clickable (especially if it’s not possible to move them away from the end of the document), so the sildes would move there and back.
Use an extra --- at the end of the document and shorten footnote text so it fits on approx. half the slide height (due to the large vertical space).
