@akaalias: thanks for the update.
TBH, I was surprised when you said it would be possible. When you sounded quite convinced it was possible, being a coding numskull I accepted it. And on that basis I decided not to wait any longer and switch from using inline footnotes to regular ones, that’s how relieved and enthusiastic I was.
Indeed, I have already experienced some confusion in the numbering difference between Edit and Preview, and caught myself thinking “I wonder when will Alexis release the reindexing upgrade?”.
OK, now I know it is not possible, so I will reconsider using regular footnotes. Yes, your plug-in as is, makes it a cinch to make them, but is it worth it? I wonder. I am the only one who can make that decision.
Many thanks for that plug-in, and more many thanks (if that’s possible
) for your effort to try the reindexing route.
Update 2 hours later: I have decided to revert to the inline footnotes because of that numbering confusion. In the theme I use the main text color draws attention more than the inline footnote text, although it is not ideal, of course. But then, nothing in life is perfect.
