Before opening a new bug report, please search the forum for duplicates and follow the Troubleshooting Guide.
- We only consider bugs that are reproducible in the sandbox vault or a vault with no third-party plugins/no css snippets/default theme.
- For Linux, we only accept bug reports that are reproducible with our Appimage package under Gnome or KDE.
- Developer issues with the API should go here
- Themes and Custom CSS issues should go here
Make a footnote using any method
Yes
I expect that when I select the text to copy to another program, the numbering for the footnotes at the bottom of the page (1, 2, 3 etc) will get copied with the footnotes.
For example I would expect this to be copied:
Sentence[1]
Footnotes:
[1]: Sentence or link explaining the reference
The numbering does not get copied with the footnotes.
This essentially tells me that the footnotes only really exist fully in Obsidian and arent compatible anywhere else. This goes against the idea of Obsidian not locking you in IMO.
Obsidian version: v1.7.4
Installer version: v1.4.13
Operating system: Windows 10 Pro 10.0.22631
Catalyst license: none
Snippets enabled: 4
Plugins installed: 0
Plugins enabled: 0
