Footnote length limitation of 1012 characters
  1. Create new note in Obsidian.
  2. Type text with three footnotes of varying lengths.
  3. The second footnote should contain 1013 characters.
Yes
That all three footnotes are rendered normally in the reading mode (including links and formatting).
The second footnote and subsequent footnotes are broken (links and formatting).
Obsidian version: 1.12.7
Installer version: 1.12.7
Language: en-GB
As I understand it, Obsidian does not have a strict, hard-coded character limit on the length of a footnote. Because Obsidian uses Markdown, footnotes can be quite long, I see no reason for a limitation like this.
Although there are practical limitations and best practices to consider, I believe Obsidian can and should provide for various use cases. In this specific case, I used footnotes for additional information and to provide context to a Bible study. The footnotes might contain a long citation comprising several consecutive verses. It is rather frustrating to be bogged down and limited to how many consecutive verses I can reference in a footnote.
I can’t reproduce this. Attach or DM me a copy of a note where this happens.
I am having the same problem. Here is my MD file. Obsidian will not render footnotes properly after footnote
albacete.gascón-2006-els.lliberts-transcript.md (81.4 KB)
5, which has 1367 characters.
thanks. I can reproduce.
