Font size of file explorer, window title and preference pane too small
The “system font” for title, file explorer and preferences pane is so small, I can barely read it. The editor font can be increased in preferences/appearance, but that setting does NOT influence the window title, file explorer or pref-pane.
I accidently decreased the font size with cmd-scroll… and since then, cannot increase the system font anymore.
When I set the font size in preferences, at least the file explorer and pref-pane will show increased font size.
see screenshot, system font too small.
OS: Mac-OS 12.2
Obsidian version: v0.13.23
Installer version: v0.13.23
Operating system: Darwin Kernel Version 21.3.0: Wed Jan 5 21:37:58 PST 2022; root:xnu-8019.80.24~20/RELEASE_X86_64 21.3.0
Catalyst license: supporter
Legacy editor: off
Safe mode: off
Plugins installed: 1
Plugins enabled: 1
1: Style Settings
all plugins are updated to their latest version.
cmd-0 / cmd-- / cmd-+
By using the menu/view/actual-size command, the system font increases. That’s a command NOT available in the usual obsidian way
cmd-0 works fine, cmd-- (cmd-minus) too. cmd-+ has no visible effect, though…
I think cmd-+ doesn’t work in some keyboard layouts.
