Obsidian version: v1.5.3
Installer version: v1.4.13
Operating system: Windows 10 Home 10.0.22631
So the note folds are stored in Local Storage and I’ve found that when you reopen the note for the first time after folding the section, a fold {from: 0, to: 0} is created for that note. This seems to somehow relate to whatever’s causing the bug because as soon as that appears, the problem starts. This doesn’t get created if there is a fold in any position other than line 1.
Turn the first line of the note Start Here into a H1
the first line being: Hi, welcome to Obsidian!
Fold the newly created H1 in Start Here
Close Start Here
Reopen Start Here
Unfold the H1 (“Hi, welcome to Obsidian!”)
Close Start Here
Reopen Start Here
Result: H1 is still folded when Start Here is re-opened
This doesn’t seem to happen if Properties are added to Start here though
Environment:
Operating system: Darwin Kernel Version 20.6.0: Thu Jul 6 22:12:47 PDT 2023; root:xnu-7195.141.49.702.12~1/RELEASE_X86_64 20.6.0
Catalyst license: supporter
Insider build toggle: on
Plugins installed: 0
Plugins enabled: 0
Make a new note or edit an existing one.
Make sure that the very first character in the body of the note is a # symbol, typically denoting a heading in Markdown. It doesn’t matter if there is one or more of # symbols, as long as the note starts with one and it results in a heading. Example: # The story begins.
Collapse the entire heading (write some text under it to easily confirm).
Close the tab/restart Obsidian.
Uncollapse the heading.
The heading will remain collapsed when you open the note from this point on. Uncollapsing it will show the text underneath, but only while the tab is open. Closing the tab in any way, including restarting Obsidian, will collapse the heading again.
This only happens if the note begins with a # symbol! If you add some text in front of the heading, the bug will not appear.
Obsidian actually remembering the state of the heading, just like it does with every other heading in the body of any note.
The very first heading of the note, assuming it starts with the symbol # and nothing preceding it, once collapsed, will return to being collapsed upon reopening the note no matter what.
Installer version: v1.5.3
ALSO TESTED ON ANDROID:
Operating system: android 13 (Xiaomi 22101316UG)
Obsidian version: 1.4.16 (114)
API version: v1.4.16
Legacy editor: off
