Fold arrow animation breaks in reading view when using the command fold all headings and lists
  1. Create a new vault.
  2. Enable the editor option fold indent.
  3. In a new file create a list with sublist and switch to reading view.
  4. Use the command Fold all headings and lists and Unfold all headings and lists in sequence to see that the fold arrow animation doesn’t change —it works when you click the arrow but not with the command—.
Yes
The fold arrow animation should work properly when we use the Fold all headings and lists command.
The animation doesn’t work and the arrows are froze in their current position.
Obsidian version: v1.7.7
Installer version: v1.3.5
Operating system: Darwin Kernel Version 24.1.0: Thu Oct 10 21:03:15 PDT 2024; root:xnu-11215.41.3~2/RELEASE_ARM64_T6000 24.1.0
Catalyst license: insider
Insider build toggle: on
Live preview: off
Base theme: light
Community theme: obsidian
Snippets enabled: 22
Plugins installed: 46
Plugins enabled: 46
1: DataLoom v8.16.1
2: Advanced Canvas v3.2.0
3: Advanced Tables v0.22.1
4: Buttons v0.5.1
5: Calendar v1.5.10
6: Charts v3.9.0
7: Code Block Enhancer v1.0.5
8: Collapse All v2.1.0
9: Convert url to preview (iframe) v0.5.0
10: Colored Text v1.2.0
11: css snippets v0.1.2
12: Creases v0.7.0
13: Dataview v0.5.67
14: Day Planner v0.27.0
15: DB Folder v3.5.1
16: Editor Syntax Highlight v0.1.3
17: Excalidraw v2.6.8
18: Extended MathJax v0.4.1
19: Hotkey Helper v0.3.20
20: Hotkeys for Bookmarks v1.1.1
21: Image Toolkit v1.4.2
22: Kanban v2.0.51
23: Multi-Column Markdown v0.9.1
24: Natural Language Dates v0.6.2
25: Note Timer v0.1.1
26: Outliner v1.4.2
27: Paste URL into selection v1.7.0
28: Periodic Notes v0.0.17
29: Plugin Changelogs v1.3.0
30: Quick Latex v2.6.5
31: Reading Time v1.1.2
32: Recent Files v1.7.3
33: Reminder v1.1.16
34: Review v1.6.6
35: Sort & Permute lines v0.7.0
36: Spaced Repetition v1.13.2
37: System Dark Mode v1.1.1
38: Tab Switcher v1.4.0
39: Tag Wrangler v0.6.1
40: Task Status v1.2.1
41: Tracker v1.14.0
42: Underline v1.3.0
43: Vault Statistics v0.1.3
44: Wikilinks to MDLinks v0.0.12
45: Admonition v10.3.2
46: Templater v2.9.1
Update installer: installer version too low, please download from Download - Obsidian and reinstall.
Community plugins: for bugs, please first try updating all your plugins to latest. If still not fixed, please try to make the issue happen in the Sandbox Vault or disable community
Does it happen with plugins disabled?~ Nevermind, I can reproduce. Thanks!
Will be fixed 1.8
Yes, it’s already there. Thanks!
