Pre-req: Ensure ‘Fold heading’ is enabled via Settings | Editor
Create a new file using the mobile app as follows:
# Heading 1
## Heading 2
Some text
## Heading 3
Some text
## Heading 4
Some text
Open the command palette and choose the ‘Fold all headings and lists’ option
All headings will be folded
It appears as if all headings are folded but, referring to the example file above, if you expand ‘Heading 1’ you’ll see that headings 2 through 4 remain unfolded.
If you go through the same process using the desktop app headings 2 through 4 will be folded, as expected.
  • Operating system: Android 11 (OnePlus 7T, Oxygen OS 11)
  • Debug info: I don’t believe this is possible using mobile app (at least, there are no results when searching the command palette for ‘debug’). In case it helps, I’m using v1.0.5 of the app.
Also true if the top-level heading is an h2:
## Heading 1
Some text
### Heading 1.1
Some text
### Heading 1.2
More text
## Heading 2
Etc.
If you Fold All and then expand an h2, the h3s below it will be expanded.
As of version 1.1.0 of the Android app, this looks to be fixed.
Thanks very much! :slight_smile:
Also fixed on iOS. \o/
