- Create a medium to large sized canvas
- Zoom or pan in the canvas
- Observe flickering of the whole UI
Yes, sandbox vault, default theme, restricted access, no plugins.
Normal zooming and panning (it worked flawlessly before).
Whole UI is flickering.
Obsidian version: v1.4.16
Installer version: v1.4.16
Operating system: Darwin Kernel Version 23.0.0: Fri Sep 15 14:41:43 PDT 2023; root:xnu-10002.1.13~1/RELEASE_ARM64_T6000 23.0.0
Catalyst license: insider
Insider build toggle: on
Legacy editor: off
Base theme: light
When the window is small enough the flickering stops (even for large canvases). Also, when I disable hardware acceleration in the settings the flickering stops. However, without hardware acceleration the frame rate quickly deteriorates.
Video with hardware acceleration enabled: With Hardware Acceleration · CleanShot Cloud
Video with hardware acceleration disabled: Without Hardware Acceleration · CleanShot Cloud
