The current implementation of path URIs doesn’t make any sense and leads to buggy behavior like the problems discussed in this thread:
The way that Obsidian locates vaults at the moment is by looking through Obsidian’s JSON-cache files instead of trying to locate the .obsidian folder. I understand how the JSON-cache is used for loading the correct data from Obsidian’s/Electron’s leveldbs, but this behavior isn’t always required for loading the vault.
I discuss how Obsidian does this on one of my blog posts: https://smartguy1196.me/Blog/2023.02.13/Unit+Testing+-+Obisidian+Plugins
This makes sense for the open?vault=... URIs but not for open?path=...
What would make sense would be for obsidian to locate the vault by the .obsidian folder similarly to how node.js finds the node_modules folder.
My method for manually adding untracked vaults somewhat fixes the issue (blog post)
