First match of note search algo is not correct even when full note title is entered
I have one note “don de forme”, and another note “induction de forme”. If I do Ctrl-O and start typing to search the note, then as I have written "don de " the first match is “don de forme”, but if I keep adding characters, including “don de f” or even the the full “don de forme” then “induction de forme” is the first match.
That search doesn’t return a note as first match even after typing its complete title looks like a bug to me, something is wrong in the matching algo.
I have reproduced it in the sandbox.
Here’s how it looks in the Sandbox vault:
For the record I stumble on this problem (almost every day) when inserting links, more than when opening notes.
I do wonder what the suggester is up to sometimes! (It hasn’t affected my workflow though.)
In case this helps, here’s a screen recording of your example with two ways to end up with the unexpected result.
Obsidian fuzzy search unexpected first suggestion 20260215
search term first suggestion
don de don de forme
don de f induction de forme
↑ The first suggestion is as expected until appending the “f”.
on de forme don de forme
don de forme induction de forme
↑ The first suggestion is as expected until prepending the “d”.
FWIW: I’m able to repro dawni’s results (in the post just above :smile: ) in the sandbox vault on Mac :blush: .
	Obsidian version: 1.12.1
	Installer version: 1.11.7
	Operating system: Darwin Kernel Version 24.6.0: Wed Nov  5 21:32:34 PST 2025; root:xnu-11417.140.69.705.2~1/RELEASE_ARM64_T6020 24.6.0
	Catalyst license: supporter
	Insider build toggle: on
And also, “Sort search results by relevance” is currently on the Roadmap so hopefully things will be improving soon. Good reliable fast fuzzy (or exact) searching is so fundamental.
I think the matching ignores distance between letters — so it sees the 2 names as equal matches despite the letters starting later and being farther apart in one of them — and prioritizes equal matches by creation date.
will be fixed 1.12.2. ETA unknown.
