Find content using dataview
find a md file with content xxx in the file
I type this in the source view
LIST FROM ""
WHERE contains(file.content, "xxx")
xxx is the content. I am searching the entire vault. XXX exists in an md file.
I have been looking on the web and in the community. My code seems right. I think I should find a list of files in the reading view. What do I have wrong?
I also tried this, but it does not work.
LIST
FROM ""
WHERE contains(file.content, "#yyy") OR contains(file.content, "#xxx")
What kind of a tag do you want to find? Just a random text? Or an actual tag like #thisTag.
Dataview don’t know anything called file.content by default. You could define a property (or field) with that name, but it wouldn’t contain the entire content of the file in either case.
If you want a general text search in all files you could look into doing embedded search queries, which would allow searches like those in the search panel.
I got my solution from AI. Not trustworthy.
I should be able to pull up the tags.
LIST
FROM “”
WHERE this.file.#xxx
xxx is a specific tag in my vault.
If you’re just looking for a list of notes with the tag #xxx, the query would be:
```dataview
LIST
FROM #xxx
