Find and Replace and linebreaks
Easy way to replace any character with a linebreak.
Requires the plug-in: Regex Find/Replace
In the Plug-In settings check the option to replace \n with linebreaks
Then simply replace with \n
I found this after searching for a while, in the question section of the plug-in:
Maybe here it is quicker to find.
Only saw the topic in this post, but I can’t add it there, since it is closed.
Thanks, May Allah bless you and guide you
