I’ve been building Agent Console, an Obsidian plugin that runs AI agents in your sidebar, and I haven’t posted about it here before – so this is the proper introduction.
It started as a fork of the excellent Agent Client plugin by @RAIT-09 (Apache-2.0). Agent Client already gave Obsidian a real in-vault agent – @-mention a note for context, ask it to write back. Agent Console keeps all of that and builds on it. Here’s what the fork adds:
Run several agents at once, in tabs. Each chat is its own tab in a single sidebar pane, so you can have one researching, one drafting, and one cleaning up a script – all in parallel. Status icons show whether each is ready, busy, or waiting on you, so you stop babysitting one before starting the next.
Pin multiple notes as lasting context. Instead of just the note you happen to be looking at, pin several notes to a chat and they stay as that conversation’s context as you move around your vault. The chat owns its context – it won’t silently swap when you open a different note.
Long chats stay light on your context budget. Pinned notes are passed by reference, not re-pasted into every message, so a long multi-turn chat uses 65–80% fewer context tokens than re-sending the full notes each turn.
It looks like part of Obsidian. It adopts your theme’s colors and styling instead of hardcoded chrome, so a custom theme restyles it like a built-in panel.
Restart without losing your place. Open tabs and their conversations reopen exactly as you left them.
Built to be dependable. You pin what the agent can see, and edits or commands wait for your OK before they run – nothing happens behind your back. Under the hood it’s held to an enterprise-grade bar: 700+ automated tests, lint and build checks on every change, and a token-efficiency benchmark you can run yourself, so it stays solid as it grows.
It works with the agent you already have – Kiro CLI, Claude Code, Codex, Gemini CLI, or any agent built on the open Agent Client Protocol. Your MCP servers come along, because it runs your agent unmodified.
The current release (1.2.0) adds a smoother first run: on a fresh install it detects an agent you already have, makes it the default, and opens the panel for you. It also cleans up the command palette and adds a one-click path to updates.
Questions and feedback very welcome.
Disclaimer
Is this project open source? Yes (Apache-2.0)
Is this project vibe-coded beyond the author’s ability to comprehend how it works? No – it is vibe-coded, but it’s built and maintained hands-on, with a 700+ test suite and lint/build checks on every change.
Save your go-to prompts and fire them in one click – the kickoffs you retype every session become context-aware chips above the composer, or a ! search right in the message box.
Search your whole chat history – find a past conversation by title or by what was actually said inside it, then reopen it in a tab.
Take a conversation to another agent – switch a chat to a different agent mid-conversation and it carries everything so far along as context.
Your sessions are safe – reopen the panel or restart Obsidian and your tabs come back; undo a closed chat with its full transcript; half-typed drafts survive.
Every agent speaks Obsidian from the first message – a built-in briefing so any agent renders wikilinks, math, and Mermaid diagrams out of the box.
Keyboard-first – every control is keyboard-operable, with hotkeys for switching tabs and firing prompts.
app.js:1 Plugin failure: agent-console Error: Attempting to register an existing view type "agent-client-chat-view"
at t.registerView (app.js:1:2616779)
at t.registerView (app.js:1:2739708)
at fc.onload (plugin:agent-console:203:37813)
Received this on both ver. 1.2 and 2.0.
Also, what does it mean, 110 commits behind Agent Client? I usually like to go for forks that are not too many commits behind.
Since it’s a fork it uses the same view name (would be a breaking refactor), so you’ll need to turn Agent Client off before you try Agent Console. It’s 100-odd commits behind because of feature divergence (Agent Client has a different approach to multi-session compared to Agent Console). Note that it’s also 300+ commits ahead due to the same reason. LMK if you still have trouble after trying the above suggestion.
Nice work. I’ve been running something similar but zero plugin: two agents (a planner and an executor) coordinating through a shared markdown handoff board note, with Claude pointed at the vault folder. Curious how Agent Console handles agents seeing each other’s output. Can one agent read another’s results, or is each sidebar chat isolated?
For the isolation question — Agent Console tabs do not share state natively, so the shared-note handoff you are describing is the practical answer. Both agents get pointed at the same note as context, one writes first, the next picks it up.
Where that pattern gets trickier is when one of your agents lives outside Obsidian entirely. I have been using a plugin called Local Sync that runs an MCP server against your vault — so CLI-based or desktop agents can read and write notes directly as part of the coordination chain. The planner writes a handoff board note, the executor reads it in through MCP, adds its output, and the whole trace ends up in your vault history.
Stacks well with Agent Console running the in-vault side. You end up with agents inside and outside Obsidian both writing to the same note, which makes it a lot easier to inspect what happened between runs.
Thanks! The chat session files contain chat history, so agents are able to see each others’ outputs. I think they could be prompted to coordinate state through their session files, but the shared markdown handoff note is something I use myself too, and it works out pretty well+is cleaner.
A few releases have landed since I last posted here – now on v2.3.0
The highlights across that span:
Searchable settings – Agent Console’s settings now show up in Obsidian’s built-in settings search (1.13) with keyboard navigation, organized into a page per agent.
Talk to it in your language – the agent can reply in Korean, Chinese, Japanese, and more, following your Obsidian language, with a one-toggle “reply in my language” switch.
Agent-offered buttons – agents can present choices as clickable buttons right in the chat, so you answer with a tap instead of typing.
Steer mid-reply – one keypress cancels the current reply and sends your redirect as the next prompt.
OpenCode is built in – now a first-class agent alongside the others (great for running against a local model).
The active tab shows its full title – the tab you’re working in widens so you’re never guessing which chat is which; close every tab and you land on a clean launcher instead of a dead end.
More reliable – sign-in prompts for remote MCP servers, notifications that open the right vault window, and a stack of stability fixes.
Update via Settings → Community plugins → Check for updates. Full notes for the latest: v2.3.0.
This one is about staying in control of what’s queued and how your tabs are organized. What’s new:
Send a queued message the moment you’re ready – when a message is waiting on the current reply, the queue banner now has a Send now button. It stops the reply and sends yours right away – no editing, retyping, or steering. The steer shortcut does the same from the keyboard.
Let AI name your tabs – right-click a tab and choose Rename with AI for a short title based on the conversation.
Quick prompts on any note with a property – a show when: entry with just a property name now matches every note that has it, whatever the value. A new show when any checkbox shows a prompt when any condition matches, not all.
Move between tabs without the mouse – tabs show a focus ring, arrow keys move between them, and focus returns to the composer after a rename.
Easier on your battery – idle chats no longer keep an animation running in the background, so macOS stops flagging Obsidian as “Using Significant Energy”. Animations also respect your reduce-motion setting.
More reliable – queued messages no longer get stuck after you stop a reply, the last messages of a chat survive a quit or reload, and reconnecting no longer leaves old agent processes piling up.
Codex users: setup now points to @agentclientprotocol/codex-acp, which replaced the deprecated @zed-industries/codex-acp. If you’re on the old package, you’ll be prompted to switch.
This one is about reaching your prompts and chats from anywhere, and seeing at a glance which chat needs you. What’s new:
Start a saved prompt from your browser, an email or a note – an obsidian://agent-console link opens a new tab with one of your saved prompts ready to send. Add the bookmarklet and one click hands a web page’s selected text, address and title to a prompt. A link can only start a prompt that’s already in your vault, and the bookmarklet always waits for you to press Enter.
Link to any chat from your notes – right-click a tab, choose Copy link to chat, and paste it into a meeting note or a project page. One click brings that chat back, even after a restart.
See which chat needs you – tab icons show a reply that finished while you were away, a turn that stopped early, or a message that failed. A new Tab display setting puts the tabs in a slim column of status icons on the side.
Tell whether an answer is 30 seconds or 30 minutes old – each message shows when you sent it, and each reply shows when it finished and how long the agent worked. While a reply runs, a status line shows how long it’s been going and when you last heard from it.
Idle tabs sleep to save memory – a background tab with nothing going on frees its agent after an hour, and picks up the same chat when you type.
Antigravity CLI is built in, a paperclip above Send attaches files, and Kiro CLI now runs on its V3 engine by default.
Kiro CLI users: on V3, --trust-all-tools and --trust-tools no longer apply. Choose Always allow for this vault, or turn on Auto-allow permissions (Settings → Permissions).
Update via Settings → Community plugins → Check for updates. Full notes: v2.5.0.
