Fenced code block attributes
I’d like to write documentation which I later publish as pdf via pandoc in obsidian. Therefore I’d like to have more pandoc features in obsidian.
My current issue is that I want captions for code blocks in my pdf. Pandoc allows fenced code block attributes to define a caption: Pandoc - Pandoc User’s Guide
I was wondering if obsidian would allow the same syntax. I do not expect any evaluation of the actual attributes in obsidian but I’d like to use the syntax to give e.g. my python highlited code block a caption in the resulting pdf while still have python highliting in obsidian.
As mentioned above, support the attribute syntaxe apart from the simple language specification after the three backticks.
I keep two versions of the same MD file.
Would love that as well. Have also been looking for a way to add captions to my code blocks (or images for that matter). Current workaround is adding an emphasized line below my fenced code block: caption. This looks good in editing mode but gets rendered with a blank line between code block and caption in reading mode (which is confusing when you have several code blocks with such a caption after one another since the space from caption to above code block is identical to the space from caption to (other) code block below).
