Please implement the ability to enter ^block-ref in a Canvas card, which would then allow navigation to the corresponding location in other files via [[abcd.canvas#^block-ref]]. The current plugins with similar functionality are:
- Obsidian Canvas Block Reference which can only link to the card, but not to a specific location. GitHub - Quorafind/Obsidian-Canvas-Block-Reference: A plugin allows you to refer card or group in canvas, and then click to jump.
- Obsidian Canvas2Document which can convert cards in the canvas into md files, but does not allow for reverse editing." GitHub - slnsys/obsidian-canvas2document: Plugin for Obsidian to convert a complete Canvas to a long form document
Finally, very grateful for your software, and thank you for all the help you have provided over time.
