Platform - Android
Obsidian Mobile version: v1.1.0
The Obsidian Android app does not seem to support edge-to-edge display. This means it can’t dynamically change the colour of the status bar and the action bar - they default to true black irrespective of dark or light themes.
It feels a bit jarring when using the light theme (which I default to on mobile). And it’s the only app on my Pixel device with this visual aberration.
For reference, this is how Android edge-to-edge is supposed to work
3
will be implemented in version 1.1.1
