- Open the editor and type
[[to bring up the link suggestion dropdown menu. - Navigate through the suggestions using the arrow keys or by scrolling (do not select a note using
Enteror a left click). - Press
|to attempt adding a custom display text to the link.
Did you follow the Troubleshooting Guide? [Y/N]
Y
The [[ should autocomplete with the currently highlighted note from the dropdown menu, resulting in [[selected note| or [[selected note |]]`, depending on whether “Auto pair brackets” is enabled or not.
The wikilink syntax remains as [[| or [[|]], without autocompleting the highlighted note from the dropdown menu.
Obsidian version: v1.7.7
Installer version: v1.7.7
Operating system: Darwin Kernel Version 20.6.0: Thu Jul 6 22:12:47 PDT 2023; root:xnu-7195.141.49.702.12~1/RELEASE_X86_64 20.6.0
Additional Information
This behavior is inconsistent with how ^ or # functions in the dropdown menu, which autocomplete the currently highlighted note before invoking block or heading reference suggestions. It also contradicts the “Type | to change display text” suggestion displayed at the bottom of the drop-down menu.
