Hello, I’m quite new to Obsidian especially to the plugins side. I’m trying to figure out how metadata menu uses values from dataview query.
I’m trying to use every heading 1 of a note as the values for a field. I’m using multi field type, but I imagine it wouldn’t be different with the other supported types. I can already extract the headings, but the problem is to match it with the expected format of metadata menu I believe.
Here’s where I’m at right now.
const page = dv.page("Test1.md");
var output = []
const content = await dv.io.load(page.file.path);
const lines = content.split('\n');
for (const line of lines) {
if (line.startsWith("# ")) {
output.push(dv.paragraph(line))
} else {
continue;
dv.list(output)
I’ve also tried using dv.paragraph(output), return output, among others.
Any help would be much appreciated. ![]()
