I know a feature in external lining where it hides the url in preview mode by this command :-
[clickME](https://www.goole.com)
in preview mode we see only this :- clickME
All i wanted to know if there is a method such that when I use backlinks
for instance, when I write the line given below in Note2 (to link to a heading in note1) [[Note01#heading03]]
then I get to see this in preview mode :- Note01->heading03
here are screenshots to make it more clear
from Note1
from Note2 (edit mode)
from Note2 (preview mode)
this stuff works fine but Instead of this can’t we have something like this in preview mode :- clickMe ( any user defined text like clickME , instead of Note01->heading03, which links to heading 03 of Note1 )
How I want that backlink to look like in preview mode ( after using this command [[Note01#heading03]] in edit mode )
@santi kindly look into this
Hey, I think I get you, let me add a couple of screenshots to see if I’m in the same page.
Say you have a daily note, and you create a heading in it that you want to reference from another note. Like this:
referencing to that block like this: (edit mode)
Preview mode (looks like this)
Alternative solution
Considering this is what you mean, asumming I understood correctly. Then there’s no way currently possible.
However I do think this will be solved once WYSIWYG is available (What You See Is What You Get) which is now on the short-term plan
trello Obsidian Roadmap
For now you can address this by using page preview
Where hovering over that link can let you see what’s in that heading.
More info here: Page preview - Obsidian Help
You could also use an embed
by putting a ! in front of the link
now preview mode looks like this
Hope one of those suggestions help!
I guess yes we are on the same page :smiley:
Still for further confirmation, you can take another look at the post as I have added the screenshots too !!
Thx for responding.
thanks for the screenshots. I made the mistake in my previous reply to use block reference, instead of heading reference.
now I know what you mean, I was a bit confused.
That is possible
This is what you do in Note2
Things originally look like this
you can add this
[[Note1#heading 3|click me]]
adding this symbol | let’s you change what you see in preview mode
Resulting in this (preview mode)
that’s called a: link with an alias
you can learn more about it here:
Add aliases to note - Obsidian Help
Thnx a lot !! Posting my query over here really helped
awesome happy to help! I’ll mark this as resolved
