Lets Import your vault to RDF
function generateUUID() { // Public Domain/MIT
var d = new Date().getTime();//Timestamp
var d2 = ((typeof performance !== 'undefined') && performance.now && (performance.now()*1000)) || 0;//Time in microseconds since page-load or 0 if unsupported
return 'xxxxxxxx-xxxx-4xxx-yxxx-xxxxxxxxxxxx'.replace(/[xy]/g, function(c) {
var r = Math.random() * 16;//random number between 0 and 16
if(d > 0){//Use timestamp until depleted
r = (d + r)%16 | 0;
d = Math.floor(d/16);
} else {//Use microseconds since page-load if supported
r = (d2 + r)%16 | 0;
d2 = Math.floor(d2/16);
return (c === 'x' ? r : (r & 0x3 | 0x8)).toString(16);
const pages = dv.pages()
const fileMap = {}
let tripples = []
for (let p = 0 ; p < pages.length ; p++) {
const page = pages[p]
const path = page.file.path
const outgoingLinks =[... new Set(page.file.outlinks.values.map(l => l.path))]
const processedLinks = {}
fileMap[page.file.path] = {name: page.file.name, uuid: generateUUID()}
delete page.file
const links = Object.entries(page).filter(([key , val]) => val.path != null).map(([key, val]) => {
const item = {from: path, to: val.path, rel: key}
processedLinks[val.path] = 1
return item
tripples = tripples.concat(links)
const unnamedLinks = outgoingLinks.filter(l => !processedLinks[l] ).map(l => ({from: path , to: l , rel: 'linked'}))
tripples = tripples.concat(unnamedLinks)
let rdf = '@prefix pkg: <https://pkg.io/>.\n@prefix rdf: <http://www.w3.org/1999/02/22-rdf-syntax-ns#>.\n@prefix rdfs: <http://www.w3.org/2000/01/rdf-schema#>.\npkg:Node a rdfs:Class .\npkg:Edge a rdfs:Class .\n'
const nodes = Object.values(fileMap).map(v => `<urn:uuid:${v.uuid}> rdfs:label "${v.name}".\n<urn:uuid:${v.uuid}> rdf:type pkg:Node.\n`).join('')
rdf += nodes
const missedPages = {}
const edges = tripples.map((t) => {
const edgeId = generateUUID()
let r = `<urn:uuid:${edgeId}> rdfs:label "${t.rel}".\n<urn:uuid:${edgeId}> rdf:type pkg:Edge.\n`
const from = fileMap[t.from]
if(!from) {
if (!missedPages[t.from]) {
missedPages[t.from] = generateUUID()
const to = fileMap[t.to]
if(!to) {
if (!missedPages[t.to]) {
missedPages[t.to] = generateUUID()
r += `<urn:uuid:${from ? from.uuid : missedPages[t.from]}> <urn:uuid:${edgeId}> <urn:uuid:${to ? to.uuid : missedPages[t.to]}>.\n`
return r
}).join('')
const missedNodes = Object.entries(missedPages).map(([key, val]) => `<urn:uuid:${val}> rdfs:label "${key}".\n<urn:uuid:${val}> rdf:type pkg:Node.\n`).join('')
rdf += missedNodes
rdf += edges
dv.header(2, 'Missed Pages')
dv.list(Object.keys(missedPages).map(p => `[[${p}]]`))
dv.header(2,'Rdf file')
dv.span(rdf)
More detals
https://medium.com/@volodymyrpavlyshyn/how-to-export-your-obsidian-vault-to-rdf-00fb2539ed18
