Export to latex project
I like writing my papers in Obsidian, but after my work is done (or to preview the output) I would like to export my project notes into a latex project.
I’m thinking about something like that:
/<project-folder>
/<project-folder>/references/
/<project-folder>/index.md
/<project-folder>/abstract.md
/<project-folder>/ieeeaccess.cls
/<project-folder>/template.tex
The plugin would consume the selected index.md file with the following structure:
# Abstract
![[Abstract]]
# Introduction
![[Problem statement]]
![[Use cases]]
![[Contribution]]
![[State of the art]]
# Background
![[Decentralized dispute resolution system]]
![[Proof to justice]]
![[Message Board]]
![[Pseudo-anonymous vs anonymous blockchain]]
![[Payment for services]]
![[Storage network]]
# The framework
![[The framework]]
# Security analysis
![[Security analysis]]
# Future work
![[Future Work]]
# Conclusions
![[Conclusions]]
and output a latex project with one index.tex, ieeeaccess.cls, and all other assets. I know that pandoc is the way to start from, but I see the following problems:
Linking
How to embed internal links ![[]] into a sections/subsections?
Bibliography
Bibliography would be identified by the bibex key-value in front matter, for example:
/references/Information Privacy Research.md
bibex: @article{smith2011information,
  title={Information privacy research: an interdisciplinary review},
  author={Smith, H Jeff and Dinev, Tamara and Xu, Heng},
  journal={MIS quarterly},
  pages={989--1015},
  year={2011},
  publisher={JSTOR}
And whenever I reference this note in some other note, e.g.
Therefore, we do not attempt to pick any definition of privacy; instead, we build on a more concrete concept that is anonymity [[Information Privacy Research]].
The plugin should recognise that this is not a section but a bibliography entry.
Abstract
This is a minor issue, but the abstract should be handled differently because in latex it’s usually embedded in \begin{abstract}...\end{abstract}.
Assets management
I’m not sure if pandoc can handle that properly.
What do you think about it? What am I missing? Is it worth doing?
I am craving this plugin.
One point I disagree on it that the bibliography should be handled via the Citations Plugin/Zotero integration, so that whenever [[@citekey]] or [@citekey] appears it creates the correct citation.
The second thing is that there should be a strong dependence on latex templates, as is the case with standard pandoc. The templates should be able to govern the structure of the export.
I think that there would need some work on the pandoc side of things, because from what I know there is no support for wikilinks in pandoc. There would be a need for a new document format in pandoc, and it would need to be able to take many files as input. I do not know if that is feasible.
I hope this can get done, it would make paper-writing from obsidian really seamless.
You are right about the bibliography at the time of writing I didn’t know about the Zotero integration, [[@citeKey]] would be amazing.
I wrote a plugin: GitHub - bingryan/obsidian-markdown-export-plugin: This plugin allows to export markdown to a folder., but there is no index.md for TOC
I also wrote a standalone tool for this in Julia: mscott99/Obsidian-Paper-Export: Export an Obsidian note to an academic paper format, including embedded content. (github.com). I someone wants to try using it let me know, I’ve only used it myself so far so it might be not very robust yet. It has many features though.
:heart_eyes: :heart_eyes: :heart_eyes: Embedded content!!!
I am in the process of paper-writing
I can convert Obsidian to Latex using the repo I created: GitHub - MariosGkMeng/Straightforward-Obsidian2Latex: A complete converter from Obsidian to Latex (write your scientific papers in Obsidian --> print to LateX)
It performs better than the existing plugins and does not suffer from their limitations (e.g., it can convert embedded notes)
