hi,
i have an export problem.
when i export my document as docx and the text contains links, i see the double brackets [[textnote]]
is it possible to change this automatically? That the brackets are all deleted?
unfortunately i can’t find anything.
i don’t want [[linktext]] in the text but only linktext.
I hope it works somehow#
thanks
i found out that if the note already exists, it doesn’t show me a double bracket.
it is difficult…
when i click text as a placeholder a note is created, this is a good workflow.
the way it is now, i have to create a note first and then paste it into another note so the parentheses don’t appear.
it probably does not work to create a placeholder and then automatically in the background the note? but that’s how it should be and certainly does not work …
very sad …
I find the solution.
[PLACEHOLDER](PLACEHOLDER.MD)
COOOOOLLLL
that´s work perfectly
If you want this, there is a plugin that does it. I’m sorry I don’t remember its name.
thank you for the answer.
i am unsure. i can’t find anything there.
it is important in the workflow that i do not change the link afterwards.
I would like to continue writing the text fluidly, without going back in the text.
if i write textnote right away, i am in the flow…
or is there a plugin?
OK, I searched and found it: the plugin is Note Auto Creator.
thank you for your effort.
this works wonderfully with this plugin.
this is how it should be…
thanks again and have a good day
