Existing Daily Note in subfolder not recognized when reopening the Note
Format of the daily note set to YYYY/MM//YYYY-MM-DD (dd)
Upon fist click to the corresponding icon in the sidebar, a new daily note with the expected format is created in the subfolder.
Every click after that creates a new empty daily note in that subfolder.
Seems that the existing note is not recognized?
Using the already created note in subsequent accesses.
A new empty note is created every time.
Obsidian version: 1.15.0
Installer version: 1.14.5
Operating system: #38~24.04.4tux1 SMP PREEMPT_DYNAMIC Tue Oct 6 21:20:38 UTC 2026 7.0.0-113038-tuxedo
Language: de
Plugins installed: 5
Plugins enabled: 5
1: Editing Toolbar v4.1.11
2: Excalidraw v2.29.0
3: TaskNotes v4.14.0
4: Tag Wrangler v0.6.5
5: PDF++ v0.40.31
Distro Name: Tuxedo OS (A fork of Ubuntu 24.04)
Distro Version:
Desktop Environment: KDE/GNOME
Installation method used: Flatpak
I also can see the same behaviour in the Android-App.
Is that a copy-paste of your date format, with the two slashes back to back (//)? If so, then try removing one so that you have just:
YYYY/MM/YYYY-MM-DD (dd)
That ought to stop the duplication.
