Excalidraw - Images are not visible in excalidraw
When I insert a copy/paste image directly into a Excalidraw-note, at the beginning I can see the image properly. But after I have left the note and I return to it, it is not displayed correct anymore. Also in all my “old” Excalidraw-notes this happened.
I tried to insert an image with copy/paste in a new Excalidraw-note, it happens again and again.
I will open one of my backups on another computer in order do check, whether this is a bug that has to do with my laptop. But I think this won´t help me with my problem.
I am having the same issue, after installing the plugin for the first time
I have to click on the image and resave it to make it appear
It is also resulting in latex equations failing to render
I think I was having a similar problem and I discovered that there were square brackets in the file name of the image and this was screwing up the interpreting of the excalidraw code in the markdown file; this may not be your particular issue but something worth considering?
