EPERM error using quartz
Im trying to use quartz for hosting my notes, it seems to work until after I do ‘npx quartz sync’, after that the command for running the server locally ‘npx quartz build --serve’ starts failing with the error
Exiting Quartz due to a fatal error: EPERM: operation not permitted, scandir 'D:
I’m on win 11 with the last version of NPM and node
some things I noticed:
- it’s a permits issue with NPX, I’ve tried to allow myself all access, also tried running with admin but it won’t work
- It won’t happen until after the first time I do ‘npx quartz sync’
I have no other npm or node projects that could be interfering with quartz
