Enabling Window Border for i3wm
Hi, I just found out that there is a linux version of Obsidian when I thought it was Mac only and I am super stoked!
I use the window manger i3 and use keyboard shortcuts to navigate through my windows. Even switching focus to another window I do via the keyboard. Normal windows get a (colored) border when they are focused, unfortunately that is not the case with Obsidian.
I checked with xprop if X recognizes the focus and it does:
_NET_WM_STATE(ATOM) = _NET_WM_STATE_FOCUSED
…but there is no border. I think Obsidian is maybe disabling all UI from the window manager to make it look the same everywhere? Is there a way to turn that back on so I can see if I am typing in the right window?
Apparently I searched the wrong way around:
“Enable Border” → “Disable Framless”
This post goes into details and even provides a workaround:
I’d still really like a feature to do this properly
