Enable transclusion view for bases
I often need to view related notes transcluded within my note. For example, when viewing a project note, I want to see all its related meetings transcluded within the project note. The reason for this is to be able to get an easy overview of what was said when, and to be able to do a quick search for when topic X was discussed related to this project.
Bases should have transclusion as an optional view. This view would show the full content of the notes within the base.
Currently using Dataview to list all related notes as ![[]]
This feature request might be related: Bases: Display, Access (and/or Filter using) the Note's Content
I do not understand this feature request.
You can see a list of notes linked from a file and the list of embeds in a file with file.links and file.embeds, respectively/
Thanks for the suggestion! However, I’m not looking for links. I want to use bases to filter, and then all notes found should be shown in full, including content. So basically as if each note in the base was displayed with ![].
ok then this is appropriate FR
