Enable applying the graph group color to unresolved links
Changing colors for not yet existing notes by applying the group color to regex filter.
For example: When creating a daily note a template inserts a date formatted so that it creates links to the year and the month. So multiple notes are now linked to [[2020]] representing the year. The year itself is not really a thing that needs explanation so an actual file for it is unnecessary but I’d still like to group years or say dates like [[07-2020]] into a group and apply a color to those nodes, so I create a graph group with regex: /20\d{2}/ or file:/20\d{2}/. The existing nodes get colored but unresolved ones retain their default color.
  • Add a toggle allowing a group to target unresolved notes
    • another solution can be a search mode that includes unresolved nodes i.e. “link-including-unresolved”.
  • Allow enabled graph groups search to target all notes including unresolved ones and apply the group color setting if a node matches a group. Might also be nice to have the opacity reduced on unresolved links to still indicate they are unresolved.
    If no group matches apply the basic “.graph-view.color-fill-unresolved”
I’ve tried creating a css snippet making the .graph-view.color-fill-unresolved transparent but it does not help because it does not work the same way .graph-view.color-fill-focused works.
Hey! Yes, you can change the color of unresolved links in the graph view using a CSS snippet in Obsidian.
Just add this code to a .css file:
.graph-view.color-fill-unresolved {
color: #E3ECFA !important;
Then, place that file in your .obsidian/snippets folder.
Go to Settings → Appearance → CSS Snippets and enable it.
You can replace #E3ECFA with any color you prefer — just use a hex code to customize how unresolved links appear in the graph.
