Embed base code block in another note
I prefer using base code blocks directly in the note, instead of embedding base files, because I try to limit the amount of files in vault.
The disadvantage of the direct use of code blocks in the notes is - as far as I can see - that they can’t be embedded in another note.
I would like to have the possibility to embed a base code block in my notes, which is written in another note.
It is still possible to create an extra header for that code block. Then I can embed that header incl. that base, but I would like to have the direct possibility.
Just adding another workaround. Block IDs work on base code blocks. So you can do:
```base
^myBase
in a note named, say “example note.md” then embed it in any note as:
![[example note#^myBase]]
You can let Obsidian assign or manually give a base-code-block a block identifier and then link to + embed that. e.g.
# h1 heading
some text
## h2 heading
```base
  - type: table
    filters:
      and:
        - file.folder == "Guides"
^base24C
some more text, yay
## another h2 heading
and in another note where you want it embedded:
![[just a note#^base24C]]
@dawni jinx!
