Editor erroneously completes bold/italics markdown inside code blocks
I’m not sure what terms to search for but I didn’t find any obvious existing report about this bug, apologies if it’s redundant…
  1. Enable “auto pair Markdown syntax” option, if disabled.
  2. Start a code block with either a single backtick or triple.
  3. Type a * or _ into that code block.
I expect auto pairing to be disabled while in a code block, since code blocks don’t support nested Markdown syntax.
It adds a second * or _ to match the one typed to the code block.
  • Operating system: Windows 11
  • Obsidian version: 0.12.19
I think you need to complete the “`” + “`” or “```” + “```” pair and type inside that.
This works for me.
