Edit ABC.js code block on Mobile
I want to edit the ABC.js code block on iPad/Mobile but I do not see an option to “Edit this block” when I tap on the music notation like on MacOS.
Blockquote
The only way I can edit the code block on iPad is to toggle source mode or going to a line below the rendered music notation and then deleting so the cursor enters into the code block.
I’m unsure if I understand your question, but I use this to access the code on iOS …
After this, both dataview and dataviewjs are seen as code.
Cheers, Marko :nerd_face:
