- Go to any settings, for example “Minimal Theme Settings”.
- Try to change a combo selection.
- If the mouse pointer is over any of the options, you will not see the others. If you move it outside, all of them are displayed.
To see all the options on a combo box, always.
If the mouse pointer is over any of the options, you will not see the others. If you zoom out, all of them are displayed.
{“version”:4,“homepages”:{“Main Homepage”:{“value”:“Diario/2024/Diario 2024”,“kind”:“File”,“openOnStartup”:true,“openMode”:“Replace all open notes”,“manualOpenMode”:“Keep open notes”,“view”:“Default view”,“revertView”:true,“openWhenEmpty”:false,“refreshDataview”:false,“autoCreate”:true,“autoScroll”:false,“pin”:false,“commands”:,“alwaysApply”:false,“hideReleaseNotes”:false}},“separateMobile”:false,“_defaultViewMode”:“default”,“_livePreview”:“default”,“_focusNewTab”:false,“_plugins”:[“nldates-obsidian”,“dataview”,“obsidian-zoom”,“obsidian-outliner”,“calendar”,“global-search-and-replace”,“ledger-obsidian”,“obsidian-tasks-plugin”,“quickadd”,“homepage”,“obsidian-media-db-plugin”,“obsidian-minimal-settings”],“_internalPlugins”:[“file-explorer”,“global-search”,“switcher”,“backlink”,“outgoing-link”,“tag-pane”,“page-preview”,“daily-notes”,“templates”,“command-palette”,“editor-status”,“bookmarks”,“outline”,“word-count”,“file-recovery”],“_obsidianVersion”:“1.6.7”}
