Dynamic markdown rendering not taking place inside a callout block
  1. Create a callout
> [!note]
  1. Create a table inside of the callout
> [!note]
> | X | Y |
> |  1  |  2  |
> |  3  |  4  |
> |  5  |  6  |
Or, create ordered lists or unordered lists.
Y
The -, the text inside of the table and the numbers in an ordered list to become grey and monospaced.
The markdown text is still in the editor font
Obsidian version: v1.4.5
Installer version: v1.3.5
Operating system: Darwin Kernel Version 23.0.0: Tue Aug 1 03:24:46 PDT 2023; root:xnu-10002.0.242.0.6~31/RELEASE_ARM64_T8112 23.0.0
Legacy editor: off
Screenshot 2023-09-08 at 19.52.18
Maybe I’m misunderstanding, but tables and lists look alright over here. You need to click out of the callout for them to render.
> [!note]
> | X | Y |
> |  1  |  2  |
> |  3  |  4  |
> |  5  |  6  |
> [!NOTE]
> - one
> - two
> - three
Screenshot 2023-09-09 091226
I could partially repro the table part in the Sandbox Vault (Obsidian Catalyst 1.4.9) but using a callout with a title :thinking:
(The callout can be a collapsing one or not, it doesn’t seem to matter)
So, this works from my side of the screen:
> [!note]
> |A|B|
> |1|2|
But this doesn’t:
> [!note] Table
> |A|B|
> |1|2|
Debug info:
	Obsidian version: v1.4.9
	Installer version: v1.4.5
	Operating system: Darwin Kernel Version 20.6.0: Thu Jul  6 22:12:47 PDT 2023; root:xnu-7195.141.49.702.12~1/RELEASE_X86_64 20.6.0
	Catalyst license: supporter
	Insider build toggle: on
	Legacy editor: off
	Plugins installed: 0
	Plugins enabled: 0
What I expect is that the table rendered immediately when my cursor goes outside of the table but still inside the callout.
we don’t support that (like wise for math blocks), search/open a FR for that
I meant that in live preview mode, if you click and edit the callout, and crate a table inside of it, the table will not render even if you take your cursor somewhere else in the callout.
The issue you reproduced is not what I meant, but also intresting.
This happens because a table needs a blank line before hand.
So
> [!note] Table
> |A|B|
> |1|2|
would work?
that was a reply to PCH post.
For your post, editing callouts does not support rendering tables, markdown, nor embeds at this point.
Ah! That a subtlety I didn’t know about :blush: !
Thanks !
TIL :innocent:
