This is driving me nuts, but I can’t figure out how to create a tag!!
I have enabled the tag pane and it is visible to me, and I’ve searched the documentation, but I can’t find an answer to this simple question. Help!
CMD+N (within the tag pane)
CMD+T
Right clicking on the file.
Thanks!
#tag
creates a header
#createsatag
:slight_smile:
Basically, this is a tag:
#tag
For more, open Obsidian Help and view the “Working with Tags” topic under the “How To” section.
Thank you. Doh! That didn’t even occur to me. So obvious. Problem solved!
