I think a video is easiest. Using the outline tool, drag a level 1 heading below another level 1 heading. I find that if I drag a level 1 “Heading 1” heading below another level 1 heading “Heading 2” in the outline, it works incorrectly, if Heading 2 is collapsed.
I would expect that whether Heading 2 is collapsed or not, that the entire contents of Heading 1 would be placed below Subheading 2.1.
Instead, Subheading 2.1 becomes part of Heading 1.
Another way of saying this is that Heading 1 is dropping into Heading 2 instead of below it.
- Operating system: MacOS
- Note that I did test in the Sandbox Vault with default theme and no plugins and it acts exactly the same, so it’s not a plugin or theme problem. This is Obsidian.app
Debug info:
Obsidian version: v1.0.3
Installer version: v0.14.6
Operating system: Darwin Kernel Version 22.1.0: Sun Oct 9 20:15:09 PDT 2022; root:xnu-8792.41.9~2/RELEASE_ARM64_T6000 22.1.0
Catalyst license: insider
Insider build toggle: on
Legacy editor: off
Base theme: light
Community theme: Minimal
Snippets enabled: 1
Plugins installed: 95
Plugins enabled: 68
1: Admonition v9.0.5
2: Advanced URI v1.29.1
3: Calendar v1.5.10
4: cMenu v1.1.2
5: Collapse All v1.5.3
6: Copy Block Link v1.0.4
7: Customizable Sidebar v2.2.1
8: Daily Activity v0.4.0
9: Dataview v0.5.47
10: Dictionary v2.21.1
11: Editor Syntax Highlight v0.1.3
12: ExcaliBrain v0.1.11
13: Excalidraw v1.7.27
14: File Info Panel v1.2.5
15: Format Hotkeys v0.1.7
16: Frontmatter Tag Suggest v0.4.1
17: Hover Editor v0.11.6
18: Mind Map v1.1.0
19: Natural Language Dates v0.6.1
20: Note Refactor v1.7.1
21: obsidian markmind v1.6.2
22: Obsidian42 - BRAT v0.6.36
23: Outliner v4.1.1
24: Omnisearch v0.2.5
25: Pandoc Plugin v0.4.1
26: Persistent Graph v0.1.5
27: QuickAdd v0.5.5
28: Readwise Official v2.0.1
29: Regex Find/Replace v1.2.0
30: Scales and Chords v1.0.1
31: Shell commands v0.16.0
32: Show Current File Path v0.5.2
33: Snippet Commands v0.0.2
34: Sort & Permute lines v0.5.1
35: Tag Wrangler v0.5.5
36: Tasks v1.18.0
37: Templater v1.16.0
38: TimeStamper v1.3.0
39: Recent Files v1.3.3
40: Archiver v0.9.0
41: Copy button for code blocks v0.1.0
42: Waypoint v1.3.0
43: Tracker v1.10.9
44: Paste URL into selection v1.7.0
45: Show Whitespace v0.3.1
46: Better Word Count v0.8.1
47: Dangling links v0.3.0
48: Dangerzone Writing v0.0.11
49: Emoji Toolbar v0.3.2
50: Pinboard Sync v1.0.2
51: Obsidian Link Converter v0.1.4
52: Advanced Tables v0.17.3
53: Contextual Typography v2.2.4
54: Dynamic Highlights v0.3.1
55: Style Settings v0.4.12
56: Minimal Theme Settings v6.1.0
57: Obsidian Enhancing Export v1.1.7
58: Excel to Markdown Table v0.4.0
59: Table Extended v1.6.1
60: Breadcrumbs v3.6.4
61: Copy as HTML v1.0.5
62: Periodic Notes v1.0.0-beta.3
63: Highlightr v1.2.2
64: Buttons v0.4.19
65: Metadata Extractor v1.0.2
66: Workspaces Plus v0.3.2
67: Commander v0.3.0
68: Local images v0.14.2
