Dragger: Notion-style drag-and-drop for all blocks
Hi everyone!
I’m excited to share a plugin I’ve been working on: Dragger.
As much as I love Obsidian, I’ve always missed the fluid, block-based movement of Notion. While the existing Outliner plugin is great, I wanted something more powerful that supports dragging and dropping all types of text blocks, not just list items.
:sparkles: Key Features
  • Notion-style Drag & Drop: Move any paragraph, heading, or block with ease.
  • Beyond Outliner: Fully compatible with standard text, not limited to bullet points.
  • Intuitive UI: Designed to make rearranging your thoughts as fast as you think.
:construction: Current Status
The plugin is currently under active development. I’m working hard to refine the interaction and ensure it’s stable for daily use.
:link: Get Involved
You can check out the progress and the code here: :backhand_index_pointing_right: GitHub: https://github.com/Ariestar/obsidian-dragger
:inbox_tray: Installation
Since the plugin is still in its early stages and hasn’t been submitted to the official Obsidian community store yet, you can install and test it via BRAT:
  1. Install the BRAT plugin from the community store.
  2. Go to Options > BRAT > Plugins > Add Beta plugin.
  3. Copy and paste the repository URL: https://github.com/Ariestar/obsidian-dragger
I’d love to hear your thoughts! What features from Notion’s drag-and-drop system do you miss the most in Obsidian? Feel free to leave a star or open an issue if you have suggestions.
Happy note-taking!
Really Well Made in looks and feel. I wish you could add side by side Text / the real Block behaviour of notion / anytype.
It’s really cool idea. Please continue to improve and develop this plugin
I’ve discovered a very serious bug in your plugin. If a note is very long, scrolling causes significant freezes.
Additionally, when working with bullet points, incorrect indentation occurs during line breaks (in sub-points)
Has this been added to the community plugins yet? In the readme it says you can search for it, but I cant find it yet. Thanks
It hasn’t. Waiting for the loooong plugin review.
Check the new version. I’ve improved the performance a lot.
Good idea. But I seems to be a tough problem. I’ll try my best. (with my codex🤣)
Hi, thank you for your update! But, in terms of performance and freezes, the situation hasn’t really changed. Maybe it’s because I work with fairly long text notes
Thank you so much – I’ve really been missing this feature for several years…
Fantastic work, this might be the straw that pushes me fully towards Obsidian from Notion!
