Drag n drop, MAC, does not work with complex file names?
I discovered that if I edit the name of an image to a long name that describes the image, I can not drag it into Obsidian. If I remove my edits on the file name, I can.
Original filename: “IMG_5658.JPG”
Modified filename: “fig.1 Inside_cut Offset + Smaller hole/slot IMG_5658.JPG”
This occurs also in the Sandbox.
The work-around is to rename the file to something simpler.
maybe this is a bug…
That / inside your new file name doesn’t seem correct. That is normally used as a folder separator. So where did you actually use that modified filename, which allowed you add that character?
holroy is spot in.
While your OS may allow the / in the filename, it won’t work for/in links (within Obsidian).
Screenshot 2025-02-03 145445
thanks guys. :+1:t6: I often don’t see what is right in front of me. :slight_smile:
